What is critical chain project management?
  • CCPM allows teams to create more realistic schedules by factoring in task dependencies, resources, and capacity.
  • The critical chain may differ from the critical path because it accounts for resource constraints.
  • CCPM uses shared buffers instead of padding every task estimate.
  • CCPM is useful when multiple projects compete for the same people, tools, approvals, or equipment.
  • Tracking tasks and buffer use helps teams spot schedule risks earlier.
Project schedules often slip when teams plan around tasks on their own. A project timeline may look realistic on paper, but delays happen when the same people, vendors, tools, or approvers are needed in multiple places at once.
Critical chain project management, or CCPM, helps teams plan around real capacity by factoring in the work, task order, and resources required to complete it.
This guide explains how CCPM works, how it compares to the critical path method, key terms, steps, examples, and tools that support planning and tracking.
Critical chain project management is a method for planning projects around the longest sequence of dependent tasks after resource constraints are considered.
In simple terms, CCPM helps teams find the most realistic path to completion by factoring in:
  • The order of tasks
  • The people or resources needed to complete each task
  • The availability of those resources
  • Buffers that protect the overall delivery date
Unlike traditional schedules that assume work can begin as soon as the previous task ends, CCPM checks whether the right people, tools, approvals, or equipment are actually available. This makes it useful for teams managing multiple projects, shared specialists, limited equipment, vendor timelines, or constrained budgets.
CCPM is based on the Theory of Constraints, which focuses on identifying the biggest bottleneck in a system and improving flow around it.
How critical chain project management works
CCPM works best when teams treat it as a practical scheduling workflow. The goal is to create a project plan that reflects how work will actually move through the team.
Here’s how the process typically works:
  1. Build a project plan with tasks and dependencies.
  2. Estimate the resources needed for each task.
  3. Identify conflicts where the same resource is needed in multiple places.
  4. Adjust the schedule to reflect realistic resource availability.
  5. Identify the critical chain.
  6. Add buffers to protect the project deadline.
  7. Track progress by watching both task movement and buffer use.
Key concepts in critical chain project management
CCPM uses a few terms that help teams talk about schedules, constraints, and risk more clearly. Understanding these concepts makes it easier to build a realistic plan and monitor progress during execution.
Concept
What it means
Example
Critical chain
The longest sequence of dependent work after resource availability is considered
A project cannot finish until design, review, development, and QA are complete, and the same engineer is needed for two of those steps
Resource constraint
A person, team, tool, budget, or equipment limitation that affects when work can happen
One designer supports three projects at once
Resource leveling
Adjusting the schedule so resources are not overbooked
Moving a task to next week because the assigned specialist is already at capacity
Project buffer
Extra time added at the end of the critical chain to protect the final deadline
Adding a two-week buffer before launch
Feeding buffer
Extra time added where non-critical work feeds into the critical chain
Adding buffer time before legal review must hand work to development
Resource buffer
A signal or reminder that a key resource will be needed soon
Alerting a QA lead before testing begins
Buffer management
Tracking how much buffer has been used compared with project progress
Escalating when half the buffer is gone but only a quart
Some teams prefer to use Gantt charts to visualize timelines to know exactly what buffers they have before hitting certain constraints.
ガント チャート
Critical chain vs critical path
Critical chain and critical path are related, but they are not the same. The critical path method focuses mainly on task sequence and dependencies. It helps teams identify which tasks determine the shortest possible schedule.
Critical chain project management, on the other hand, adds resource availability to the project schedule. This can change the true longest path through the project because work may be delayed by overbooked people, limited equipment, review bottlenecks, or shared tools.
Critical path method
Main focus
Task dependencies and sequence
Task dependencies plus resource constraints
Key question
What tasks determine the shortest possible schedule?
What tasks and resources determine the realistic schedule?
Resource planning
Often considered separately
Built directly into the schedule
Schedule protection
Usually added to individual task estimates
Centralized in project, feeding, or resource buffers
Best for
Mapping task order and deadlines
Managing constrained resources and reducing delays
Progress tracking
Tracks task completion against dates
Tracks work progress and buffer consumption
How to use critical chain project management in 6 steps
CCPM starts with a clear project plan, then adjusts that plan based on resource reality. These steps can help teams move from a task-based schedule to a capacity-aware schedule.
Step 1: Define the project scope and outcome
Start by clarifying what the project must deliver. Before building a schedule, teams should agree on the objective, project deliverables, success criteria, key stakeholders, and target delivery window.
A shared planning page helps everyone align before the schedule is built. Using a project plan template helps teams document project scope, owners, milestones, assumptions, and decisions in one place.
プロジェクト計画のスクリーンショット
Step 2: Break the work into tasks and dependencies
Next, map the major activities required to complete the project. This includes the obvious production steps as well as reviews, approvals, handoffs, testing, and launch activities.
For example:
  • Design must be approved before development starts.
  • Legal review must happen before customer-facing messaging goes live.
  • QA testing cannot begin until development work is complete.
  • Stakeholder approval may be required before launch.
Teams should capture both formal and informal project dependencies, since undocumented handoffs often create delays later.
A clear project timeline can help teams see how tasks connect and where delays may affect downstream work.
Step 3: Estimate resources for each task
Each task should include the resources required to complete it. This may include people, roles, specialized skills, equipment, budget, approval time, or vendor availability.
This is where resource planning becomes essential. Teams should look for shared resources that appear in multiple parts of the project.
A designer assigned to three campaigns, a developer supporting two releases, or an executive approver needed for multiple launches can all become constraints.
Strong resource management helps teams understand not only what work needs to happen, but whether the team has the capacity to do it within the target timeline.
タイムラインのスクリーンショット ビュー
Step 4: Level resources and identify the critical chain
Resource leveling means adjusting the schedule so people and resources are not overbooked. Once resources are leveled, the longest realistic sequence of work becomes the critical chain.
For example, imagine a product launch requires design, development, QA, and final approval. On paper, designing the landing page and email campaign may look like parallel work.
But if the same designer owns both tasks, one must happen before the other. That resource conflict may extend the true project schedule.
This step is closely tied to workload management, because teams need visibility into who is doing what, where capacity is limited, and which assignments may create bottlenecks.
スプリント ビューのスクリーンショット
Step 5: Add project, feeding, and resource buffers
CCPM reduces excessive padding in individual task estimates and protects the schedule with visible buffers instead. This makes scheduling risk easier to monitor because extra time is managed at the project level rather than hidden inside every task.
The three main buffer types are:
  • Project buffer: Extra time at the end of the critical chain to protect the final deadline
  • Feeding buffer: Extra time where non-critical work feeds into the critical chain
  • Resource buffer: A reminder or signal that a key person, team, or tool will be needed soon
Step 6: Track progress and manage buffer consumption
During execution, teams should monitor both work completion and buffer consumption. A task may be moving forward, but if buffer time is disappearing too quickly, the final delivery date may still be at risk.
A strong project tracking process helps teams monitor task status, owners, due dates, blockers, dependencies, and schedule risk. Teams can also use a risk register to document risks tied to resource constraints, approvals, vendor timelines, or unresolved blockers.
After the plan is defined, Jira can help teams turn the schedule into trackable work. Teams can assign owners, update statuses, flag blockers, and keep execution visible across the project.
Paired with Loom, teams can also support quick async updates when buffer use, timeline changes, or blockers need more stakeholder context than a written status update can provide.
Loom 録画のスクリーンショット
Build more realistic project plans around your team’s capacity
Critical chain project management helps teams build schedules around real constraints instead of ideal conditions. By accounting for task order, dependencies, resource availability, and buffers, teams can create plans that are easier to execute and less likely to slip unexpectedly.
CCPM is especially useful when multiple projects compete for the same people, approvals, tools, or budget. It gives teams a clearer way to identify bottlenecks, protect deadlines, and respond before small delays become larger delivery problems.
Be realistic about your project plans and consider how critical chain project management can help.
Critical Chain Project Management FAQs
When should you use critical chain project management?
Use critical chain project management when resource availability is one of the biggest risks to your project schedule.
CCPM is helpful for complex projects, cross-functional work, multi-project environments, and teams that rely on shared specialists, limited equipment, outside vendors, or approval groups.
Is critical chain project management agile?
Critical chain project management is not the same as Agile project management, but the two can work together.
  • Agile focuses on iterative delivery, adaptability, and continuous feedback
  • CCPM focuses on resource constraints, realistic scheduling, and buffer management
What is an example of critical chain project management?
A software team planning a product launch might need design, development, QA, legal review, marketing, and executive approval. The original schedule may show several tasks happening at once.
However, the same designer and QA lead may be needed across multiple workstreams.
With CCPM, the team identifies those shared resources, adjusts the schedule so they are not overbooked, and finds the true critical chain. It also adds buffers to protect the launch date.
During execution, the team tracks both task progress and buffer use to understand whether the project is still on schedule.
