Search
Transform teamwork with Confluence. See why Confluence is the content collaboration hub for all teams.Get it free
Feasibility study: What it is, types & how to conduct one
Key takeaways
  • Every proposed project looks good in theory, but a feasibility study helps teams figure out whether the idea holds up against real-world constraints
  • A feasibility study examines a project from multiple angles so the team can make an informed decision before committing resources
  • Teams that skip a feasibility study often discover problems mid-execution that could have been identified during planning
  • A well-structured feasibility study gives decision-makers the evidence they need to move forward confidently, revise the approach, or stop before wasting time and budget
Not every promising idea turns into a successful project. Some run into budget problems. Others stall because the technology isn't ready, the timeline is unrealistic, or the organization isn't equipped to support the change. A feasibility study is designed to catch those issues early, before a team has already invested significant time and money.
This article covers what a feasibility study is, why it matters in project planning, the different types of feasibility assessments teams can run, and a practical framework for conducting one.
What is a feasibility study?
A feasibility study is a structured assessment used to determine whether a proposed project or solution is practical and worth pursuing before execution begins. It forces teams to move beyond enthusiasm and look closely at whether the idea is realistic given the organization's capabilities, resources, and constraints.
Think of it as a reality check. Before a team drafts a full project proposal, a feasibility study tests the assumptions the project depends on and identifies the biggest risks standing in the way.
What does a feasibility study evaluate?
A feasibility study typically examines a project from several angles. The specific areas depend on the project, but most cover some combination of the following:
  • Technical practicality: Whether the required technology, systems, tools, and expertise are available or can be acquired within the project's constraints.
  • Financial viability: Whether the projected costs, funding, and expected return make the investment reasonable.
  • Operational fit: Whether the organization's existing workflows, staffing, and processes can support the project without major disruption.
  • Legal or compliance considerations: Whether the project faces regulatory, contractual, or policy requirements that could create barriers.
  • Scheduling realities: Whether the project can be delivered within a realistic timeline, accounting for dependencies and competing priorities.
Feasibility study vs. business case
A feasibility study and a business case serve different purposes. A feasibility study tests whether something can and should work in practical terms. A business case focuses on why the investment is worth making and what value it could create. Here's how they compare:
Feasibility study
Business case
Purpose
Tests whether the project is workable
Justifies why the project is worth doing
Focus
Practicality and viability
Value and justification
Key question
Can we do this?
Should we do this?
Outcome
Helps teams decide whether to move forward, revise, or stop
Helps stakeholders approve or fund the project
In practice, a feasibility study often comes first. If it confirms viability, the business case builds on those findings to argue for funding and approval.
Why do feasibility studies matter in project planning?
A feasibility study gives teams a structured way to evaluate a project before they commit. Without that step, organizations risk moving forward based on incomplete information. Here are the most common benefits:
Reduce project risk
Identifying obstacles, constraints, and weak points before execution begins gives teams time to address problems while changes are still inexpensive. A risk assessment matrix template can help organize and prioritize what you find.
Validate key assumptions
Testing whether the team's expectations about cost, resources, timing, or implementation are realistic prevents plans from being built on faulty premises. Solid project estimation depends on this kind of early validation.
Assess overall project viability
Helping teams determine whether the project is practical and worth pursuing saves organizations from investing in initiatives that were never going to work.
Support better go/no-go decisions
Giving stakeholders clear evidence to decide whether to move forward, revise the plan, delay, or stop removes much of the guesswork from high-stakes decisions.
When to use a feasibility study
Teams should use a feasibility study when a proposed project involves meaningful cost, complexity, risk, uncertainty, or organizational change. Small, low-risk tasks rarely need this level of scrutiny, but for anything that requires significant investment, a feasibility study helps prevent expensive missteps.
Here are common situations where a feasibility study adds the most value:
Before launching a new project
Initiatives like implementing new software, opening a new service line, or building a product feature set all benefit from a feasibility check. A project manager can use the study to set realistic expectations before the project enters the next phase of the project life cycle.
Before making a major investment
When teams need to justify budget, staffing, or timeline commitments, a feasibility study provides the evidence that resource planning decisions should be based on.
When project assumptions need validation
A team may have a promising idea but still need to test assumptions around demand, resources, technology, or delivery capability.
When multiple approaches are possible
A feasibility study can help compare options before committing to one path, so teams don't lock into a direction without understanding the tradeoffs.
Types of feasibility studies
Different projects raise different concerns, and not every feasibility study needs to cover every angle. Most teams focus on the areas most relevant to their situation. Here are the five most common types:
What it assesses
Common questions
Technical feasibility
Technology, systems, tools, expertise
Can we build or implement this successfully?
Financial feasibility
Budget, costs, value, return
Can we afford this, and is it worth it?
Operational feasibility
Workflow fit, staffing, adoption
Can the organization realistically support this?
Legal/compliance feasibility
Regulatory and policy requirements
Are there legal or compliance barriers?
Schedule feasibility
Timeline realism and dependencies
Can we deliver this on time?
Evaluates whether the organization has the technology, infrastructure, and expertise needed to execute the project.
Examines whether the project's costs are justified by its expected value and whether funding is available.
Looks at whether the project fits within the organization's existing workflows, staffing capacity, and culture.
Legal and compliance feasibility
Assesses regulatory, contractual, or policy requirements that could create barriers.
Determines whether the project can be delivered within a realistic timeline given dependencies and resource availability.
How to conduct a feasibility study in 5 steps
A feasibility study doesn't need to be overly complicated, but it does need to be methodical. Here's a practical framework:
1. Clarify what success would actually look like
Outline the problem the project is meant to solve, the intended outcome, and what success would look like if the initiative works as planned. Clear project objectives give the rest of the study a reference point. Setting goals at this stage keeps the study grounded and focused.
2. Pressure-test the project's biggest assumptions
Identify the assumptions the project depends on, such as available budget, internal capacity, stakeholder support, technical readiness, and timeline expectations, and examine each one critically. Most project failures trace back to untested assumptions that turned out to be wrong.
3. Examine feasibility from different perspectives
Assess the project across the most relevant feasibility areas. Not every project requires a deep dive into all five categories, but skipping an area that matters can leave a blind spot that derails execution later.
4. Compare the most realistic paths forward
Most projects have more than one possible approach. Look at tradeoffs such as cost, complexity, timing, risk, and expected impact to determine which path is most workable. An iterative process can help here. Teams can refine their options as new information surfaces during the study.
5. Turn the findings into a clear recommendation
State whether the project appears feasible, what conditions may need to be addressed first, and whether the team should move forward, revise the plan, test further, or pause.
What to include in a feasibility study report
A formal feasibility study report gives stakeholders a clear, organized view of the findings. Most reports include these sections:
Purpose
Executive summary
Summarize the project, findings, and recommendation
Project overview
Describe the project and why it is being considered
Objectives and scope
Define goals, boundaries, and intended outcomes
Assumptions and constraints
Outline key assumptions, limits, and requirements
Analysis by feasibility type
Evaluate feasibility across relevant categories
Risks and dependencies
Highlight major risks and project dependencies
Options considered
Recommendation
State the recommended decision
Next steps
Outline what happens after the study
Tips for conducting a more effective feasibility study
A feasibility study is only useful if it produces honest, actionable findings. These tips help teams get the most out of the process:
  • Focus on the biggest feasibility questions first: Prioritize the areas that carry the most risk or uncertainty rather than trying to give equal weight to everything.
  • Use evidence, not assumptions: Ground every conclusion in data, research, or direct input from subject matter experts.
  • Keep the scope realistic: A feasibility study that tries to answer every possible question takes too long and loses focus. Define what's in scope and stick to it.
  • Compare realistic options: Avoid comparing an ideal scenario against clearly inferior alternatives. The goal is to evaluate options that the team could actually pursue.
  • Make the recommendation clear: Decision-makers need a direct answer about whether a project is feasible, not feasible, or feasible with conditions.
Use feasibility studies to make better project decisions
A feasibility study is one of the most practical tools a team can use before committing to a new project. It brings structure to the evaluation process, surfaces problems early, and gives stakeholders the evidence they need to make informed decisions.
Confluence gives teams a single place to build, share, and refine a feasibility study from start to finish. Use pages and live docs to draft the study collaboratively, tables to compare options and constraints side by side, templates to standardize how your team evaluates recurring projects, and whiteboards for early brainstorming and stakeholder alignment.
Explore Confluence to see how it supports better project evaluation and planning.
